If is BMW coolant, DO NOT USE ANYTHING BUT BMW COOLANT!!!
can i put green coolant into my BMW E34? thanks a lot
M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
use the OEM stuff, i'ts blue. I would not go within 10ft of my car with green coolant...ever!
Originally Posted by sirius_GTO
Green is for old AMC pacers
green works just fine
my car had green in it when i bought it, i replaced it with blue. Both can be used, blue is better.
I use Prestone. It is green.Originally Posted by sirius_GTO
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
i heard prestone is the one to lookout for. Aparently it eats away at the aluminum... Is this true?
1995 BMW 530ia/3.15lsd/M Parallels/Eibach/Bilstien/Magnaflow
Green, orange, blue...
I had a horrible experience with orange coolant in my GMC Envoy. Cost the warrantee company $1,000 because I let that **** kill the water pump rather than pay the $250 for the chemical flush.
I would not use anything but BMW coolant. The piece of mind is worth twice the price difference.
six forward speeds
I just changed mine on my '91 525. I used the Zerex G05 (Yellow). Here's a link to product info, and a neat chart that Zerex provides. BTW, I picked up the coolant at Autozone for somewhere around $10.99.
http://www.valvoline.com/pages/produ...asp?product=10
http://www.valvoline.com/zerex/pdf/Z...d=1B5D1AEA1AFC
1991 525i
