Results 1 to 3 of 3
Thread: emission control air pump questions M60
    Crozet, va
    Default emission control air pump questions M60
    Hi all,
    my air pump is showing some rust. Not sure why, but I'll look into that. My questions are:
    1. what is it?
    2. Do I need it?
    My indy pointed out that it was looking long in the tooth (rust) and will need to be replaced. The part is > $700!
    1995 530i Alusil 190K
    they suck, as long as it still powers up don't worry about it other then see if you can keep the moisture out of it, sometimes the valve on the tubing going to the exhaust fails allowing condensation to be blown into the air pump, othertimes it's a bad design on the duct feeding it, it's not a required part but it will throw a check engine code, you can make used ones from 850/960 volvos work by changing the cover on the big end and electrical connection on the small end, pretty much every obdII bimmer and volvo has one that can be made to work
    Crozet, va
    Thanks. I think I'm going to pull it and see what I can do to get rid of some of the rust, etc. thanks again
  1. Water pump replacement - Two more questions
    By ElNormo in forum 5 Series BMW
    Last Post: 07-19-2009, 02:58 PM
  2. Water pump replacement - Two questions
    Last Post: 07-17-2009, 10:00 PM
  3. Some fuel pump questions
    Last Post: 02-01-2008, 04:37 PM
  4. Replies: 3
    Last Post: 03-20-2005, 01:14 AM
  5. emission control air pump 11 72 1 742 286
    By bpattan in forum 5 Series BMW
    Last Post: 09-02-2004, 02:02 PM
