Results 1 to 10 of 12
Thread: Help - E34 wont start
    Dec 2006
    Waterloo, ON Canada
    Default Help - E34 wont start
    95 E34
    I turn the key and nothing (like I'm trying to start it outside of park)
    Central door locks no longer working, interior auto lights not coming on.
    I've checked fuses and cannot see any blown. Battery is still good - dash lights, radio, headlights all come on. Tried boosting with another vehicle - nothing. Checked fusible link - everything looks good - no cracks
    Any ideas?
    Just incase anyone was interested....
    $1200 later - the door lock capacitators were shorted - driver and passenger. Other wiring and shorting had occurred. Computer thought the doors were locked and would not engage the starter !!
    8 hrs of diagnostic and repair to electrical wiring system under the rear seat.
    Ouch
    East Brunswick, New Jersey
    Is the battery charged? How old is the battery?
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Bay Area, CA
    Sounds like a dead battery. If none of your interior lights come on, its probably a dead battery. Test for voltage at rest and during crank. Rest voltage should not be below 11 volts. Voltage during crank should not be below 9 volts.
    Greg Mannino
    Dec 2006
    Waterloo, ON Canada
    Quote Originally Posted by gmannino
    Dec 2006
    Waterloo, ON Canada
    Great Britain
    Sounds like classic sysmtoms of a cracked fusible link.
    Have a rummage around bmwe34.et until you find the section about replacing the fusible link.
    Simple check would be to try jumping it with another vehicle/known good battery. I,ve had mine fail to start due to a weak battery, the car would run, but not send enough to the solenoid to start.
    Plus, jumping is free
    Is your battery under the seat? If so, I believe your fusible link would also be there somewhere. If the batt. is in the engine bay, the fusible link sits aft of the passenger side strut tower, under a little black plastic cover.
    Welcome Ontarian.
    Aug 2005
    Iowa, USA
    Also if your battery is bad it may draw away the boosting current to itself as opposed to the starter
    1995 525i "Stefanie"
    Dec 2006
    Waterloo, ON Canada
    Welcome Ontarian.
    Yeah - tried jumping but to no avail...
    Battery is under the seat - where abouts under there is the fusable link - what does it look like?
    Dec 2006
    Waterloo, ON Canada
    Quote Originally Posted by pingu
    Fusible link is fine - took it apart and inspected it - no cracks
  1. 92 525 wont start
    By kzpuck in forum 5 Series BMW
    Last Post: 04-25-2008, 05:22 AM
  2. Help!!!! Car wont start!!!
    By GoldenOne in forum 5 Series BMW
    Last Post: 09-24-2006, 09:08 AM
  3. car wont start...
    By pong in forum 5 Series BMW
    Last Post: 09-16-2006, 03:59 AM
  4. 92 E34 M20 Help - Wont Start
    By eddie_uk in forum 5 Series BMW
    Last Post: 07-07-2006, 12:32 PM
  5. Car wont start
    By 1991 525i Novs in forum 5 Series BMW
    Last Post: 06-16-2006, 04:16 PM
