OK, pulled 95 525 out of storage. Everything OK. Two days later, needed fair amount of brake fluid. Thought that was a little odd. Few more days and very little resistance on clutch pedal. Raining like a bitch so difficult to see oil leaks from slave. Master is not leaking. Car has about 105,000 miles.
When slave goes bad must it shows signs of leakage or does it just give up and lose hydraulics.
Got info from Bruno's site about install. Thx.
It will either slowly leak out and eventually leave you stranded when it sits long enough, or it will explode on you - either way you will lose hydraulics and will be stranded unless you can drive with the synchros.
At least thats what the 2 I went through did.
dave b
93 525i
156k +
