i doubt it will hurt anything as long as the hang over doesn't get into some place bad
I just noticed today. Are there any negatives to this setup? Almost all the pads are this size. I say almost becasue over on m5board.com in their e34 section they talked about ferodo pads that where slightly smaller in size. http://www.m5board.com/vbulletin/sho...8&postcount=38
Enjoy life on the bleeding edge Kristian!
Just think, at least you are getting full the bang for your boot. I hate it when my pads miss out on the last mm of full circumference bite. What is with that kinda design??? Hmmm
My guess is incorrect rotors.Originally Posted by genphreak
I think pundit was responding to genphreak's post.Originally Posted by BigKriss
they will be hard to get out when they are worn out,there will be a huge lip which you will have to force the piston ALL the way back,you will prolly overflow the master cylinder resevoir
Gone but not forgotten
I had this problem, but disconnecting the brake line, opening the bleed screw and putting an overflow tube on it allows you fully compress the piston without dealing with the reservoir. Bleed thoroughly when reattaching.Originally Posted by Paul in NZ
o/______\o
(Oo=00=oO)
Well obviously it risks de-centreing the caliper and getting a 2.7mm less throw on one side, 2.7mm more on the other. I guess the pistons will (under pressure) manage it, but there might be a problem when the pads wear out... or (for some reason I can't imagine) you may gt more force on one side of the rotor and end up with warped rotors... but i can't see how it would matter on the face of it...Originally Posted by BigKriss
btw Kriss, when is the head coming off? Nick
