Results 1 to 2 of 2
Thread: check engine light 535i
    Apr 2004
    DFW
    Default check engine light 535i
    meh.
    What are the most common causes of a check engine light? Its been stalling out while idling if I push in the clutch just enough while my foot is off the gas. :\
    I thought it was my stuck throttle cables causing all the stalling, but would jacked up throttle cables cause a check engine light?
    USA
    throttle position sensor?
    oxygen sensor?
    do a stomp test.
  1. check engine light flickers with engine miss
  2. Engine check light
    Last Post: 02-11-2006, 01:06 PM
  3. 92 535i, check engine light at idle
    By scoobysmak in forum 5 Series BMW
    Last Post: 02-01-2006, 09:18 AM
  4. Can bad gas cause the check engine light to come on?
    By Jersey General in forum 5 Series BMW
    Last Post: 11-14-2005, 11:24 AM
  5. check engine light
    By george in forum 5 Series BMW
    Last Post: 09-08-2005, 10:11 PM
