make sure you have the tps plugs correct - if reversed, will trigger asc light & erratic idle.
I have two that are apparently bad and they cause my throttle to stick and idle erratically. I need to try anthor icm before I drop the $250 to get a new one. I will pay shipping both ways and then some for anyone help on this. Thanks in advance!
May the Schwarz be with you...
I believe my problem lies with my ecu. I will try that first since the problem began after incorrectly inserting an ecu chip backwards and melting my wiring harness. Hopefully that will take care of it.
