Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Suspension noise
    Vancouver, Canada
    Default Suspension noise
    I will update tomorrow or later tonight with a list of parts that have already been replaced since I've had the car but I'm hearing a sublte noise when going over small bumps and road imperfections at lower speeds. It sounds to me like a thick glass bottle bonking around in a wooden box, but muffled. Blonk, blonk? Haha, I love my technical descriptions. Seems to be coming from the front though.
    n
    Roswell New Mexico
    i have the same sound, i was thinking it was just worn out tie rod bushings
    Vancouver, Canada
    Nope, all that is brand new. A couple other forums have suggested swaybar links.
    Honolulu
    Default Jack it up
    put it on stands
    and inspect the ball joints, stabilizer link & bushing etc.
    use a big water pump pliers to try to wiggle and compress the ball joints
    use a big prybar to try to move the arms and stablizer.
    look for torn boots and loose stuff
    Bloomington, IN
    Actually.. I believe I have the same exact sound coming from the front of my car. it sucks.
    If the collar nut on a strut is loose you'll get a dull rattle.
    Nov 2006
    bay city michigan
    I had a lot of front suspension parts replaced and a few days later had that dull thump sound I think you are describing. One sway bar link was not tight enough. It seemed tight on the hoist but I guess once the cars weight was on the ground every small bump at slow speeds you could here it. Put a box end wrench on the bolt and noise went away....
    Feb 2007
    brooklyn
    is it coming from the front or back?
    Jan 2007
    San Jose, CA
    I get the same noise, but I thought it was my highways/fogs rattling around. I noticed they are rather loose and can be shaken around quite easily. Banging on the panel they sit in seems to create a similar noise IMO.
    Vancouver, Canada
    Pretty sure it's not the fogs, just not the right kind of sound for that. I will check the collar nut and sway bar links. In the middle of moving at the moment so I won't get to it for a bit.
    Thanks for the help guys!
    n
  1. bump noise on front suspension
    By mystic_525_tds in forum 5 Series BMW
    Last Post: 06-21-2008, 03:28 PM
  2. Noise from the front suspension
    Last Post: 12-16-2006, 08:10 PM
  3. Suspension noise.
    By yy101 in forum 5 Series BMW
    Last Post: 12-01-2006, 05:48 AM
  4. Suspension noise...but from where?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 03-01-2005, 11:31 PM
  5. 535 Suspension Noise
    By hdaemon in forum 5 Series BMW
    Last Post: 06-10-2004, 03:12 PM
