Thread: Dead Battery and Sunroof
    Jan 2005
    SF Bay Area
    Default Dead Battery and Sunroof
    I did a search on this topic but didn't find anything. Stupidly, I left my key in the on position yesterday after opening the windows in the morning. I didn't realize it until evening. Battery was dead. I put the charger on it over night. Starts fine, windows, OBC, radio...Everything works except for the sunroof. Battery is only a few months old. It's in the pop-up vent position but nothing happens any way I press the button. Any help is appreciated.
    Steve
    Steve
    SF Bay Area
    1992 525i/5-spd, 250K mi
    17inch wheels
    Default Manual closing
    Quote Originally Posted by BlackOnBlack
    Steve
    There is a key behind the panel next to the sun roof switch. Have you try using it to manually close the roof? Just pry the panel off the instructions are in the owner's manual. Good luck!
    Try doing a complete reset on the car. This is also known as the Shogun reset. Basically you disconnect the - and + cables from the battery and with the ignition switch in the ON position put the two leads together for a few minutes. Make sure you have the code for the radio before you disconnect the battery. More often than not, electronics will come back to life after a reset. HTH
    Honolulu
    Default try the key
    in the driver's door, turn all the way to lock and hold it for a 10 seconds. this will close any open windows and the roof.
    Jan 2005
    SF Bay Area
    Thanks for the input. I was going to do the shogun reset but decided to go through a couple of remote lock cycles. That worked fine and then I tried the key all the way to the right once more and got the sunroof to close. Then turned the key on and the sunroof worked properly. Confusing, but what the heck. Thanks for the input.
    Steve
    SF Bay Area
    17inch wheels
  1. Sunroof Dead
    By hlenoble in forum 5 Series BMW
    Last Post: 10-02-2007, 09:13 PM
  2. Battery Dead, cant get in!
    By chief_rucka in forum 5 Series BMW
    Last Post: 11-16-2006, 12:44 PM
  3. Dead battery?
    By howardc64 in forum 5 Series BMW
    Last Post: 09-14-2005, 03:20 AM
  4. dead battery
    By guinness in forum 5 Series BMW
    Last Post: 08-11-2005, 05:14 PM
  5. Dead Battery...Can't get in
    By pineman in forum 5 Series BMW
    Last Post: 11-19-2004, 02:12 PM
