Results 1 to 4 of 4
Thread: uneven ride height
    Default uneven ride height
    Hey Guys, Just noticed today that my car is sitting very low at the rear passenger wheel and the two front wheels are raised quite high, also the rear driver side wheel is also a little high, any suggestions as to what is wrong ?and how to fix this ?
    Thanx guys 4 your help much appreciated
    Fraser
    Nov 2006
    Mid-Atlantic, USA
    Quote Originally Posted by Fraz06
    ...any suggestions as to what is wrong ?and how to fix this ?
    Year? Model? Mods? Bueller?
    Derbyshire, UK
    Must use ESP to identify vehicle... *Concentrating* *Concentrating* *Concen-*
    Got it! It's a 1975 Reliant Robin!
    Your problem is that the Reliant Robin is a three-wheeled vehicle. If you see two front wheels, someone has probably shoved one under there as a joke. That is what's pushing it up on the driver's side and making it sink on the passenger side. Also, check to make sure your severely overweight mother-in-law isn't still sitting in there; those little cars really aren't made to haul that kind of mass.
    1997 535i V8
    USA
    shocks and springs, shocks and springs!.. and pads and mounts.
    the back left spring might be cracked, or the spring pad disintegrated.
    might as well get all new ones to sharpen up the handling while you are screwing around with the suspension
  1. Rim size / ride height advice needed
    By wjbell in forum 5 Series BMW
    Last Post: 05-06-2007, 02:58 PM
  2. How do I reduce my ride height just a little more?
    By Jay 535i in forum 5 Series BMW
    Last Post: 07-23-2006, 05:15 PM
  3. Stock ride height
    By Alexlind123 in forum Suspension & Steering
    Last Post: 08-29-2005, 01:01 AM
  4. Stock ride height
  5. Ride height difference at rear wheels
    By Mas (UK) in forum 5 Series BMW
    Last Post: 04-27-2004, 04:52 PM
