Need more information.
Do you have roof rails? Are the rubber inserts in place, or are the rails open to the elements? Check your driver door carefully. Inspect all rubber seals, window, door, etc. If you really want to find out, go to a car wash with a friend and have him/her sit in the drivers seat while you blast the seams around the door. Also, if you do not have the rubber inserts in your rails, you should blast the front rail with soapy water to make sure that the bubbles come up in the back rail area and vice versa. You may need to use weed wacker trim line to ream out your drains. Another area is the space between the hood and the windshield.
Car wash with a friend may give you results the fastest.
hth
