Results 1 to 8 of 8
Thread: Cat
    Feb 2007
    GreenHills East-Philippines
    Default Cat
    took out my cat now my check control display "Catalyst" how can i get rid of that? I mean is there any sensor i could bypass or something? tnx.
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Cincinnati, Ohio
    O2 sensor simulator would get rid of it. Not sure if it would mess with your fuel map or not.
    Dec 2006
    Long Island
    I just did some crap yesterday as an experiment.
    I have a Mazda van with a bad cat. It kept triggering the MIL.
    Here's what I did:
    Went to local pep-boys and in the HELP! section i got spark plug anti-fouler 18mm. Drilled one out to fit the 02 sensor then screwed it into another anti-fouler. Reinstalled the o2 sensor with its new 'shield' and the light doesn't come on anymore. It might work for you and it was only $4.
    Feb 2007
    thanks a lot guys for the reply.unfortunatly i can't find one so i improvise...now its gone thanks again
    Feb 2007
    Quote Originally Posted by bmwrp8 View Post
    sorry to revive an old thread but i still have this problem, does anyone have some ideas?
    Default Spark plug non-fouler/o2 sensor trick
    http://forums.evolutionm.net/showthread.php?t=215795
    http://www.energeticforum.com/renewa...n-foulers.html
    http://forums.evolutionm.net/showthread.php?t=114931
    http://www.scionlife.com/forums/viewtopic.php?t=55631
    http://www.preludeonline.com/f28/hom...ective-168992/
    It's pretty much a spacer you put between the o2 sensor that goes on your cat. When you install test pipe a cel comes up. The spacer moves the sensor out of the direct flow of the exhaust. Fooling the system.
    http://www.preludeonline.com/f28/wha...er-mod-237059/
    http://www.scionlife.com/forums/viewtopic.php?t=101069
    Original purpose:
    Spark Plug Non-Fouler
    Spark Plug Non-Fouler Operation:
    A fitting used on the electrode end of a spark plug. It minimizes exposure of the plug electrode to oil fouling in the combustion chamber. It raises the spark plug higher in the chamber and away from high concentrations of fouling agents.
    El Paso TX
    thouse antifouler hacks only work if the sensor itself is ok.
    if the sensor is bad, or you have no bung for it an a replacement pipe you can try this.
    http://www.vfaq.com/mods/O2bypass.html
    Feb 2007
    Quote Originally Posted by attack eagle View Post
    i'll try them again. thanks for the input guys
    attack eagle=> if the sensor is bad and we'll just bypass it, is it ok? i mean won't there be any idle issues?
