Originally Posted by
beetos
Cheers,
Had a feeling it would not work.
Its carnage under the rocker cover, both arms on #4 have broken, makes me very concerned that 2 arms on one cyl have gone. Was not revving hard, just pulling 5,000 rpm when it started running on 5.
Head off time.....
I'm in the process of doing the exact same thing.
I THINK you can get to the fronts if you can tip the engine up (disconnect drive shaft and mounts) and perhaps remove the radiator. Have to look to be sure, but I'm pretty sure you don't have to do as Bently's says and pull the whole dang cam shaft. I pulled the head to check the valves (got a broken exhaust rocker on cyl#2). Looks like you can position the cam at the right spot, slide the rocker arms to the side and get enough slack to free the rocker arm.
Oops - I see you're concerned about #4 though, so no dice there. Remember to mark the location of your cam gear teeth WRT the head with the crank at TDC before taking the chain off. The chain can slip teeth on the crankshaft end, when the tension is out, so even if you're really careful not to move anything it can still accidentally slip and be off. Don't ask me how I found that out...
Robin
72 Chevy K10
01 E39 M5
