He has posted a couple of charts that show the interchangeability (I think) of different brakes (Disc's and Calipers) it also has the part numbers as well.
Cheers!
BnZ
I hope so, because I can get the calipers etc etc VERY cheap if they do fit!
Craig
Cheers!
BnZ
bmwe34.net talks about it in detail
89 Mazda MX-6 GT :: 78 Suzuki GS550E :: 90 BMW 535i/5 :: 02 BMW 330i :: 97 Jeep Cherokee Sport
arent they the same calipers?
slightly larger i believe
rotors are a little larger so i'd assume the calipers would be too. different part numbers at least
the chart and this ^^^ is taken from bmwe34.netOriginally Posted by bmwe34.net
front, the calipers and 28mm thick rotors are a direct drop in
rear, the hubs have a different offset but it doesn't really matter as they are pretty much the same brakes on a 735 as the e34, 740/750s have vented rear which are nice, i swapped the trailing arms (bolts right in) to get them on my 535, slotted e32 fronts and vented rears work well
so how big of a difference are you expecting if you swap out the front rotors and calipers? I have access to a parted 735 is it worth the swap? Is there noticable bite? or will it throw off the balance from front to rear?
