Results 1 to 5 of 5
Thread: M50 positive crankcase ventilation design
    May 2006
    Antwerp, Belgium
    Default M50 positive crankcase ventilation design
    Hi, I've a theoretical question that ties into something I just noticed.
    Is the connector pictured under number 1 in the link below a simple connector or a valve?
    http://www.realoem.com/bmw/showparts...84&hg=11&fg=15
    From what I've read the PCV system should export blowby through there into the intake manifold. I'm just curious what the function of each line is and and if it's true that the PCV air intake is attached to the air cleaner box.
    If it'd be just a connector then why two separate lines (one thinner and one thicker)? Also if the connector is leaking around the base is that bad?
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
    Connecticut
    Mine was weeping oil out around the valve/connector so I replaced the o'ring which was probably original. Nice & dry now.
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    baton rouge, loserana
    simple vapor seporator/connection, it attempts to draw a slight vacuum on the crankcase while not sucking oil, if it's leaking and not cracked it just needs a o-ring, the usual problem is the two lines going from it rotting off under the intake
    May 2006
    Antwerp, Belgium
    The thin one doing what? I'm thinking about replacing them both and I'd like to know what spec of tube it is: diameter, hardness, etc.
    2008 audi A3 1.9tdi
    you can get them through the dealer and they are not too expensive, that yay they are the right size and grade to deal with the heat and oil
    11 15 1 726 828
    11 15 1 735 150
    11 15 1 730 507
    are the three # my computer coughs up for the breather hoses at around $20 for the three, you car may be slightly different being a 520
  1. Replies: 13
    Last Post: 06-05-2009, 09:50 AM
  2. Crankcase Ventilation System Check For.....
    Last Post: 04-21-2009, 08:13 PM
  3. E36 crankcase vacuum problem
    By myles in forum 3 Series BMW
    Last Post: 03-10-2008, 04:28 AM
  4. Design 2 vs Design 3 19# Injectors
    By tvurt in forum 5 Series BMW
    Last Post: 08-18-2006, 01:51 AM
  5. bad gas milage and crankcase vent?
    By pyro in forum 5 Series BMW
    Last Post: 11-20-2005, 09:08 AM
