Originally Posted by
Unregistered
The hoses on my 94 530 were leaking as well. After looking into to doing it myself, I gave up and reluctantly went to the dealer...a bit pricey but worth it to have them do it. Unfortunately, I let the resevoir run a bit low too many times and now the pump is a bit noisy. So one day, I'll prbably get into replacing it.
You mentioned the motor mounts.....I need to do mine. The drivers rotted away from all the damn power steering fluid.....it craked and leaked all the fluid out....I thought I had an oil leak, only to find out it was the motor mount. Did you replace yours yourself? They look like a pain in the rear to get to. From the bottom they look easy enough, but how do you get to the top bolt?
Any help at all would be appreciated.
Mark
94 530i
