from another board...Originally Posted by ricola
Enter the six digit radio CODE that came supplied in the radio supplement booklet and use the six radio preset buttons to enter the CODE. If you have 3 failed attempts of entering the radio CODE...you must leave the ignition in (position 1) and the radio on for at least 1 hour....then try again.
If when entering the CODE you hear a BEEP before you've entered the last digit...stop and start over with the first digit of the CODE. If you mess up while entering the CODE...continue thru to the sixth digit and start over after the radio BEEPS.
When you've sucessfully entered the CODE, the radio will BEEP and CODE will disappear from the radio display.
(Remember you only get 3 attempts at entering the CODE)
