Results 1 to 3 of 3
Thread: starter failure bulletin
    Default starter failure bulletin
    BMW Starters
    September, 1998
    Technicians should be aware that repeated starter failure on almost all
    BMW built between 1984-1994 is due to a bad or sticking ignition switch
    assembly. The vehicles affected are E30, E32, E34 and E36 which for those
    who may not be familiar with BMW designation means any vehicle from 318I
    to 850 CSI.
    Service bulletin 120393 (3824) dated May 1995 outlines the problem
    requiring the replacement of the ignition lock cylinder, ignition switch and the
    starter. Additionally a special starter protection relay has been developed that
    should be wired into the starting system.
    Check with the BMW dealers because some of these are a (free-of-
    charge) fix if the vehicle qualifies.
    Source: Electrical Connection
    11/98
    Found it on this website
    http://www.genco1.com/tech_tip_details.cfm?id=32
    Aug 2004
    Dubai
    thats strange ... how many did face this problem so far? I never heared of such a fault in any BMW from those listed. only frequent problem was the ringy starter that was due to the flywheel I guess. does the V12 have 2 starters? and that leads us to replace all the above X 2?
    no man, we have only 1 starter. my 530 is doing the ringing occasionally.
  1. Replies: 1
    Last Post: 11-29-2010, 10:33 PM
  2. Replies: 3
    Last Post: 06-29-2008, 10:03 AM
  3. importing vehicles to Australia bulletin
    Last Post: 01-24-2008, 06:19 AM
  4. starter failure bulletin
    Last Post: 02-06-2007, 06:08 AM
  5. ZF 5HP 30 - technical bulletin
    Last Post: 09-26-2005, 03:03 PM
