Results 1 to 7 of 7
Thread: Manual swap Differential
    Nov 2006
    Norfolk, VA and Coats, NC
    Default Manual swap Differential
    I have most of the parts I need for my 5-speed swap into my 525iT. What differentials will work? If it will work, I am considering the 3.46 from the manual 535i. Or would it be better to just get a 3.23 from a 525i?
    Also, how bad will the revs be on the stock 4.10, if it will bolt right up?
    I'm hoping this will be my summer break project
    Connecticut, USA
    3.46 might be a little low for the M50, might be perfect
    4.10 will be at like 4500 on the highway
    1990 Islandgrun 535iM Sedan
    3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
    Nov 2006
    Quote Originally Posted by ILoveMPower
    Holy hell! That's outta the question then
    Connecticut
    5th gear in the 525 5 speed is 1.00. In the 535i tranny it's .81 making the 525i 19% lower. With the same (3.46) rear diff the 525i is going to rev much high. If you do much highway cruising you might want to stick with a stock 525i manual diff.
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    Fogtown
    Quote Originally Posted by John B.
    5th gear in the 525 5 speed is 1.00. In the 535i tranny it's .81 making the 525i 19% lower. With the same (3.45) rear diff the 525i is going to rev much high. If you do much highway cruising you might want to stick with a stock 525i manual diff.
    But that most likely means no LSD.
    FS: PBR Deluxe rear brake pads [new]
    Connecticut
    Quote Originally Posted by Anton CH.
    Why? None of the 5 speed 525i models came with LSD?
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Nov 2006
    Okay, I've been crunching numbers on an engine calculator and found this out using the 3.23s and 3.46s on a 1:1 transmission output on a 25.5in OD tire (roughly a stock 205/65-15)
    Rearend 3.23 3.46 4.10
    60mph 2550 2750 3250rpm
    70mph 2990 3200 3800rpm
    80mph 3400 3650 4325rpm
    100mph 4275 4550 5425rpm
    So I don't think the 3.46 will be too extreme, if it will be a direct bolt in swap. Will the acceleration difference be highly noticable over the 3.23?
  1. differential swap: 3.23-->3.64
    By romeox929 in forum 5 Series BMW
    Last Post: 04-07-2007, 09:02 PM
  2. E36: how 2 swap a differential - DIY
    By shogun in forum 3 Series BMW
    Last Post: 08-02-2006, 03:15 AM
  3. Help:E32 735iM to E34 535iM Differential swap?
    By grave77 in forum 5 Series BMW
    Last Post: 11-03-2005, 08:48 AM
  4. differential swap question for 1991 535i
    By Robert K in forum 5 Series BMW
    Last Post: 02-13-2005, 12:18 PM
  5. Differential Swap Question
    Last Post: 08-08-2004, 10:03 PM
