was some kind of molded plastic ended one from Mann.
it worked the same, but I don't have that plastic do-dad adapter.
just oredered another liter or ate super blue and an oil filter. i decided to go with a metal ended one because i can always pull out the plastic support correct? its a mahle one if that matters. i have no idea which one the car has in it now.
Plastic... the redesigned it because of loss of oil pressure upon startup. That insert keeps oil in the filter rather than to let them drain out. I still have one metal filter that I bought by mistake... u want it?
You forgot wooden.
They are interchangeable?
no. the metal ones WILL NOT fit in the oil filter container designed for plastic filters.
Will a plastic fit on a orig metal?
no, the entire canister was redesigned.
its just an insert that can be removed for the metal end filters.Originally Posted by BillionPa
So when did this all take place? What should I expect to find in our new 95 525iT? I was planning on dumping the oil this weekend & have a Napa filter with metal ends. Should I wait until the filters I ordered from BMA arrive & just return this one?
90 535im
02 R1100S, 87 R100S
76 R90/S,73 R75/5
Alfa Romeos- 65 Giulia Spider Veloce
& 66 Duetto 1600 Spider
