You mean manual? S6S 420G ZF gearbox no connection with GM.Originally Posted by markus
Jan
and how much do they go for used? im wondeinrg if the ones from the early 90s vettes would work.
Jan
Sorry Jan, the S6S 420G is a Getrag box, not a ZF box. BMW's transmission specification jargon spells it out --Originally Posted by Yaninnya
Sport6Speed 420 (the amount of torque the transmission can handle) G (manufacturer - Getrag in this case). The S6S 420G is the name BMW gave to the Getrag G286.6.
Corvettes use a Tremec T56 6 speed behind the LS-1. The gearing is all different, even if you fab a custom bellhousing. Considered doing this behind a V12 conversion a year or so ago, not worth it.
Of course! You right. Where I get this ZF from?Originally Posted by Kalevera
Jan
I paid almost $2000 for a 6 speed corvette setup
ZF makes the autobox for the v8s
how much does a used 6 speed go for anyway? theuerodepot wanted like $2k!
The last one I had went for a grand --
http://www.bimmer.info/forum/showthread.php?t=19680
whit smokes too much crack and is incognito
if i rememebr correctly someone had one in here not long ago and they wanted like $125 for it.
Is the box the same as the E34 M5 6 speeder ?
