Originally Posted by
mitchc
I found a streaming oil leak on the Exh. side of the head, which seems to be coming from the fwd side of the #3 exhaust port, right above where the block bulges up like there is an oil passage cast into the block (this "bulge" seems to run from bottom to top).
Does it sound like the oil leak is from a leaking head gasket due to the overheat, even tho the compression is okay? And The stumble- could that be from a bad sensor somewhere or ICV? Seems to me to be two different problems, am I headed in the right direction?
