This might help
http://72.14.203.104/search?q=cache:...s&ct=clnk&cd=3
When you scroll down, there will be a highlighted Bosch #701, that is the injector used for the 3.6 M5. The 3.8 Euro used Lucas injectors. One of the main differences between the two, Lucas was a disc type and Bosch was a pintle type. The injectors are interchangeable, but the Bosch units are 3 times the cost of the Lucas. Some fellow E34 M5 enthusiasts have changed from the Bosch units to the Lucas with reportedly good results.
The flow rates for the Lucas units are 290cc/min. or 28 lbs. per hour
The flow rates for the BOSCH units are 240cc/min. or 22.85 lbs. per hour
Since replacement cost for the BOSCH units is prohibitive, I've been looking at Injector shops that will rebuild and flow test my existing injectors back to factory specs for something like $20 an injector.
I wouldn't think you would want to "upgrade" your injectors as they already dump copious amounts of fuel into the cylinders. I think new replacement Lucas injectors are like $60 USD each.
Hope this helps,
JR
