how hard is it to replace those little buggers? i have some leaking where the hoses meet the master cylinder on my car. the parts are cheap and i figure i might as well replace my brake fluid at the same time. So which fluid do you guys like and how much? Seems like ATE super blue is popular and comes in blue and gold to alternate when you change. My brake fluid is a dark brown color and is kinda milky so im sure its time for fluid. Hopefully it will reduce pedal effort. Can I bleed the brakes myself or do i need the dealer to do it because of the ASC? Also I noticed I have some seepage of brake fluid underneath where the rubber line meets the hard line. its the spot on the drivers side underneath where the rubber line connects to the line in the back. I obviously need a new rubber line because I was tooo rough replacing my thrust arms. unforuntatley real OEM doesnt make identifying the hose easy. If someone can take a pic id appreciate it to help identify the hose I need.
