I just did this, you need to 'preload' the bearing 5-8mm as I recall, pushing it toward the front of the car. (there is a procedure for this in the Bentley book). I've put about 500 miles on mine, no issues that I am aware of.
sc
i got the old one off and the new one on, but as soon as i tighten the 19mm bolt all the way, the bearing takes a lot more effort to spin, i think it should spin freely, any ideas guys
1990 Islandgrun 535iM Sedan
3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
sc
scott 4991
535i, 172K miles
i heard about that but it is not even in the car, do you think that tension is fine, did i put it on backwards or somthing?
im scared to put it back in the car with that much friction, anyone?
I'm about to do the same procedure soon. Where's the friction exactly coming from ? I guess the new bearings are always a bit stiff..
but it spins freely untill i tighten it up
it is like the coupler on the front shaft is hitting the rubber once it is all tight
I can not help at this point. Mine worked freely, I did not try it after tightening, just did the pre-load and it worked fine.
sorry I can't provide more info.
sc
scott 4991
535i, 172K miles
how did you put the centre bearing onto the spline?
it is hard to explain but ill try, the bearing is in a sleeve type thing where it can only come out one way, well i put the open part towards where the other half will come in on the spline , it is how the old one was when i took it off it just seems that there is rubber rubbing somwhere
