Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: So ...... where do I stick my gong then?
    no...would say you need to look a bit deeper on "your driver side" i.e. the right hand side of the car. The wire harness for the gauge cluster including the connector for the gong I would say would be above the peddle facia embedded in the literal maze of wires you see running under the cluster. Look hard for a small 4 way connector right at the boundary if not tucked up into the cluster bundle. Key off where the whole is in the peddle facia...looks like a 2 inch round hole with a rectangle cut out through the sides of the hole. Don't think you will find this connector under the glove box side of your car.
    HTH,
    George
    Apr 2004
    Colchester UK
    Awwww ... and I've just put it all back together again now ...... in the dark .... Ah well , there's always tomorrow I suppose
    Default I'm RHD too...
    I'm right hand drive, and my gong speaker is underneath the steering column, as someone else said it's behind a holed grill not too far from the peddles. I don't know if your car would have the grill as it didn'thave the gong to begin with, but the connector should be there... if you have one...
  1. How I fixed my gong:
    Last Post: 12-05-2006, 08:47 PM
  2. Where can I stick my...
    By BM-BOY in forum 5 Series BMW
    Last Post: 09-22-2005, 12:13 AM
  3. OBC but no Gong...!
    By EonPeon in forum 5 Series BMW
    Last Post: 07-17-2005, 08:37 AM
  4. FAQ on using BMW paint stick?
    By tim in forum 5 Series BMW
    Last Post: 01-04-2005, 10:20 AM
  5. Wouldn't it be neat to stick a LED...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 04-22-2004, 04:03 AM
