Results 1 to 10 of 10
Thread: Rear Axle oil ...
    Dec 2006
    San Jose, CA
    Default Rear Axle oil ...
    OK, I admit it, I have NEVER changed the rear axle oil and see in the manual it uses 2 quarts of SAE90. Is this hard to do? I assume a drain plug like the oil I change regularly! (see, I do some maintenance). I will look into this more, but any opinions on how often this oil should be changed?
    sc
    scott 4991
    535i, 172K miles
    Honolulu
    Default Check to tag on the back of the rear end
    if you have an LSD ( look for a S on the tag), then you'll need 140.
    Use a good quality synthetic
    So. California, USA
    I've never done that either. How often does the axle oil need to be changed and how? Thanks.
    (SOLD) 92 525ia M50 | NGK plug | JVC AR560 | EAT chip | California
    Honolulu
    Default If you never done it
    do it
    Minneapolis, MN
    Default Open filler plug first
    Real easy, but be careful and use jack stands. The trick is having the right hex socket and a breaker bar. Make sure you open the filler plug first because if you can't open the filler then you don't want to drain the diff as you will not be able to refill. Also, get new sealer gaskets. My diff was leaking badly when I bought my car, thought I was in for major $s. Turns out the po had used a really bad sealing ring on the drain plug. I happened to have a couple extra gaskets from my Saab 900 (same size as Saab oil plug gasket) and that took care of the leak.
    1992 BMW 525iT (sold)
    1998 V70R
    New Jersey
    Sorry to hijack...my rear is whining, I changed the oil twice in the last 2 years. My indy used 90w I think, was fine until this fall when I noticed some noise when driving with the windows closed. The last time I bought Royal Purple 75-90w with LSD additive. It didn't improve the noise. Would using the 140 decrease the noise or should I start thinking about looking for a new rear end? Bently doesn't specify weight, just has letter designations...I was told by the dealer to use the 90w.
    Frisco, TX
    Definitely make sure the filler plug can open first. Mine were a major pain to get off. You can get a special Facom tool that fits in there pretty good. Not much room to work with.
    Lexington, Kentucky
    Some models require synthetic lube. I know the 95 does, I believe, every 60,000 miles. I think the non-sythethic should be changed every 30,000 miles. My indy used Redline in my 95.
    Lexington, Kentucky
    You may need to replace it. I had an e28 that did it for years. I was told the only practical option was to replace with a factory rebuilt or used diff. Typical shops do not generally rebuild.
    Default Get new gaskets and use 75w90 Mobil1 synthetic.
    As others have said, get the gaskets first and make sure you loosen the fill plug before draining out the axle
    And, being entirely anal, I replace my tranny fluid (Mobil1 Synthetic ATF), rear axle fluid (Mobil1 75w90) and power steering fluid (Mobil1 Synthetic ATF) along with the brake fluid (Ate Typ200/Super Blue) and engine coolant (Genuine BMW w/Distilled water) every 2 years.
    "Uncle" Phil C
    2011 Kia Optima EX-P.
    Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
    03 R1150RT 6spd. "DaRTth"
    00 R1100R 5spd. "LeRoy"
  1. weight distribution E32 front rear axle
    Last Post: 02-23-2008, 06:48 AM
  2. Bad rear axle bearing.
    By wiebuschk in forum 5 Series BMW
    Last Post: 07-31-2007, 12:40 PM
  3. Help with parts reference, rear axle.
    By gmannino in forum 5 Series BMW
    Last Post: 11-25-2006, 11:06 PM
  4. Rear Axle
    By colamangr in forum 5 Series BMW
    Last Post: 06-20-2006, 12:46 AM
  5. rear axle stand location
    By moots in forum 5 Series BMW
    Last Post: 07-04-2005, 12:05 AM
