Rig up temp power to the horn to see if it is still working, if yes, then it would be your horn ring that needs to be fixed.
Hey every1,
I've got a 89 520i and the horn ain't working no more, i've checked the fuse and it seems to be in order. Any idea's as to whats wrong and how to fix this?
thanx guys
if the fuse is good, and the horn is good, it may be the switch in the wheel or some kind of relay. if thats the case, break out the multimeter.
