Is the noise not there when the engine is running?
Could just be the heater valves opening and shutting if your heating isn't full on or off.
Right after I turn the car off, I get this noise that sounds sort of like an electrical antenna going down. It's not constant like that though, it more like 3x with about a second or two in between. It seems to be coming from within the instrument panel.
No A/C running, defroster, etc. Any ideas?
2008 audi A3 1.9tdi
(former 1991 520i LPG)
lol yeah, sounds like the usual, it's kinda loud isn't it...
"nee nrrrrrrrrr nee nrrrrrrrr nee nrrrrrr"
so annoying...
I get something similar as well except it's when I turn to position 1 or 2 (I forget) but before I turn the car on and it sounds similar, but kind of a fast grinding buzz.
EuroLux:. Private Detail
You know, I have had the same thing with my car since i got it, but i always forget about it until i hear it again. [Somtimes my seats squeak alot when getting out so i dont hear it] Mine sound is kind of soft, like there is a motor of some sorts with a gear on it, trying to move but backs off and then tries again, it dosnt last more then 10 seconds with me, I thought it was just some otehr part of the car doing its thing :P
No ill effects with the sound that i know of yet, I am going under my dash again to replace my Fan blower resister this weekend maybe i can have a look and let ya know what i see/hear
I know that sound! Someone please tell us what it ts.Originally Posted by CharlesAFerg
The noise you're hearing is the wiper arm pressure adjusting device.
Item no.4.
It is a motor independent of the wiper motor that increases the wiper arm pressure against the screen to prevent the wiper arms from lifting off the screen at high road speeds. It's a whirring motorized noise that appears to emanate from behind the instrument cluster.
It usually begins within 30 secs of start up and also occurs again just after shutting the engine off.
The noise lasts about 5 to 10 secs and is quite loud.
the motors resest for a few seconds after you shut down.
You probably didn't notice it unitl you got the AC fixed and ran the system.
