uuuuuuuuuuuum what?
do you mean the actual bilstein unit disassembled, or the rear strut unit stripped down to individual components?
i ordered new bump stops and sleves and mounts for my rear bilsteins but Im not sure if I will have eveyrhting I need Such as little rubber gaskets on the bottom and what goes underneath the mount? The idea for me is to assemble them before I put them on the car.
uuuuuuuuuuuum what?
the rear strut stripped down to see the bump stops and stuff. I looked at real oem but no avail.
Lookie lookie I found you a breakdown. Its an e32 diagram, but is the same as an e34.
http://www.realoem.com/bmw/showparts...=33&fg=45&hl=1
ok so what else will i need? I know im going to need a lower and upper spring pad as well as #2/ Are the spring pads nesecary? Also what is number 5?
#5 is the existing aluminum assembly if you have it, no need to replace it.
maybe this will help
http://www.bavauto.com/assets/imglib500/b46_1486.jpg
what are the 4 other brass pieces in this picture? I know the one part is where the spring sits but what about the other 2 parts, not the nut but the thing with the hole in the middle. Also Do I need to use spring pads?
sorry for all the annoying questions.
thats all the crap that comes with the shock, its the top limiter that hits the bumpstop, the spring perch, a sleeve so the shock will fit the small and large shock mount and the top bolt.
nothing else to report on this post...lol
did u run spring pads or no?
sure did, keeps things quieterOriginally Posted by markus
