when i did mine not too long ago, i started from the top with the window fully open, you sort of push down and sqeeze at the same time and the top part should go in, the bottom half should follow, but don't forget the clips move around in the cards a bit so make sure they're lined up with the holes in the doors before you tap them in with your hand otherwise you'll end up with a load of busted clips, hope this helps
