finally I found this relay that i have no label of to be the culprit in the front engine also in front of other fuse box compartment ...can someone pleasse help with I D of the relay in other box. It seems to be pulling 130a ??
Quote Originally Posted by PaulJ
Don't confuse the detection and measurement of voltage with that of current. Voltage can be present without the flow of current so the actual detection of voltage at the fuses is not what you should be concerned with if you are looking for battery drains. The instruments and techniques for troubleshooting these problems (if this is really the issue) have been covered thoroughly in the archives and can be accessed by searching them. A relevant set of prints for your vehicle would be a good starting point.
Paul
