No rings, no spacers. Should mount right up just fine. Make sure you get tires to fit the E34's smaller wheel wells though. 7 series fitment are too big.
http://cgi.ebay.com/ebaymotors/18-BM...spagenameZWDVW
i know they are fropm an E38 but will I need rings and spacers?
1992 525i 5 speed (Calypso/Parchment) - 1989 525iA (Schwartz/Natur) SOLD
Direct fit other than tires as stated above.
You only need 245/40 R 18 for fronts and 285/35 R 18 for rear! They are not staggered only parallels for E39 where staggered (they are 8 wide fronts and 9 rears).Originally Posted by markus
couldnt i just run the same tire size all the way around?
You could but then they wouldn't be staggered.
The M pars. on the E38 were 18 x 8 and 18 x 9.5. On the E39 they were
18 x 8 and 18 x 9. You can use the same size tires, they will still be staggerd. If you look at the picture, the lip is wider on the rear wheels than the fronts.
