I can tell nobody wants to deal with obd2
therefore not passing NYS inspection. WTF? I remember the scanner wasn't working in the port, thought it was a bad connection or something. Went for inspection and the car isn't outputting info from the port. No MIL's or related issues. Tried again with Snap-On MT-2500 still no signal. Scanner powers up and reads no connection. Any ideas???
Too many cars that need work... Looking for a beater E32/E34/E36 to use while i finish a couple projects
Some of the earlier E39 models had trouble with the pins on the plug connection, I believe there was a Technical Service Bulletin concerning the pins pushing back into the connector and not being able to make contact.
Might have a good look at the plug, you'll have to stand on your head for this one!
JR
Originally Posted by Jr ///M5
Thanks for the reply, i will check as soon as it gets light out. Thanks!
Here's the "pin-out" for the connector. Just remember when using a code reader or scanner, the ignition has to be in the "on" position, or else the reader will read error.
http://www.bmwtips.com/tipsntricks/reset-plug/reset.htm
download the PEAKE manual here
http://www.peakeresearch.com/manual.htm
There is aso something mentioned about trouble with pic connections
