Check fuse first...
I was trying to reset the Service Indicator Lights on the dash
but had no luck. Now I find that I have no Instrument Lights, Gauges not moving and Fuse 1 keeps blowing. Man am I in trouble please help if you can.
Violia
Check fuse first...
Have checked fuse and replaced with others still no helpOriginally Posted by Tiger
How did you try resetting them? Did you purchase a reset tool? or did you make a reset tool? Also...What year and 5er do you have?
Racing King (Mississauga, CA) has a reset tool for $20 CAD:
http://www.racingking.net/Canada/scr...?idproduct=461
Works pretty well. Or you can make your own, there's a writeup floating around somewhere ,i'll try to fish it up....
sounds like the general module is toast...
oh yeah, explicit details on your car and the procedure you were performing would be helpful in diagnosis.
Have checked fuse have kept changing fuse still no help keeps blowing.Originally Posted by Tiger
Did not purchase rest tool should have. 1989 525i E34 M20 2.5 litres.Originally Posted by Felixdacat
Made tool myself stupid me used piece of resistant wire.
The Bimmer is a 1989 525i E34 M20 2.5 litres. Originally we were trying to reset the Service Indictaor Lights on the dashboard but had no luck.Originally Posted by BillionPa
Now we have no Instrument Panel Lights, Gauges are not moving, No Brake Lights and the Fuse thay carries the laod for all of these things Fuse No 1 keeps blowing, have tried other fuses and still they blow, have checked for loose wiring could find none.
We took a piece of resistant wire and joined it between Pins 7 & 1 and it did not reset what did happen was what I have described above.
Violia
