Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: So I'm gonna say F it...
    La Mirada, CA
    Default So I'm gonna say F it...
    So **** the guy who sold me the crappy Hella EE's...I'm gonna get BRAND NEW ones for xmas. So I'm thinking to myself, when I put those in, why not put in HID's at the same time.
    Looking for 4300 or 5000k's (so I dont get rolled), how does this kit look to you guys?
    http://cgi.ebay.com/ebaymotors/Brand...ayphotohosting
    Aside from def. talking to Tim, (TC535i), anyone else have any input?
    PS, so I changed my fuel filter today, my shop teacher said I did not need to clamp the lines, and I ended up with gas all over myself. The good part about auto is that I had like 3 other people helping me get the new one in, without minimal spilage.
    Tell your shop teacher:
    With the engine running, remove the fuel pump fuse. A few seconds later the engine will cut out, but you will have reduced the pressure in the pipes. Now switch off the ignition.
    Then you have not much spill.
    Or just take out the fuse then turn the engine over a few times. It will just sputter and die. Same concept though... Just a little less sketchy in my opinion. For no good reason really.
    USA
    do it! 5000K is the pure white color, whereas 6000 has a slight blue tint and 4300 has a slight yellow tint (even though the post says that about the 5000)
    Indiana
    6000 is where it's at. EE's and 6000k is what I have.
    As for where you're getting them from, sounds good, I've had two of my friends buy from that seller and were very happy.
    T·O·R·O·N·T·O
    Want light? Ok 5000k. Want to be a little bit different? Go 5000k... that will enhance the blue/purple cutoff fringe even more without being "poser-xenox-overwattage-bulb-blue" like.
    Hockinson, Washington
    Quote Originally Posted by danielhstout
    That actually sounds like a better idea to me. I have removed the fuse while the engine was running numerous times for injectors, fuel filter and fuel level sender; and i never feel too good about the engine sputtering and vibrating as it dies. Next time i will just crank the engine with the fuse out.
    BTW, clamping hoses on cars of this age is probably not a good idea unless they have been replaced recently, thats probably why your shop teacher recommended against it.
    TC535i Guest
    Any news on the braking noise? Top up the power steering fluid yet?
    TC535i Guest
    Too much $$ on the HID kit. PM me, I'll get you set up with a set way cheaper.
    BTW, are you getting normal headlights or smoked?
  1. who's gonna jump on this?
    By HDhandyman in forum 5 Series BMW
    Last Post: 10-18-2006, 05:36 PM
  2. Someone is gonna get a slammin deal on these.
    By ericcamaro in forum 5 Series BMW
    Last Post: 08-06-2006, 07:08 PM
  3. The only thing I'm wondering is who's gonna be
    Last Post: 03-02-2006, 02:32 PM
  4. Just bought my first e34...its gonna be interesting
    By drmmaster in forum 5 Series BMW
    Last Post: 11-01-2005, 09:49 PM
  5. OT , how are you gonna know?
    Last Post: 05-18-2004, 12:41 PM
