Results 1 to 7 of 7
Thread: ETK questions(a bit long)
    Wellington,New Zealand
    Default ETK questions(a bit long)
    Ok Jeff and did a deal and i have the 5 cd set of the tis etk ksd and the electrica trouble shooting discs.Jeff recomends that i run the various applications from the cds which makes perfect sense.However I have the sysadm installed from the etk disc and it always wants to install the whole etk(or whatever)Also i had the etk installed and punched in my chassis no but it did not seem to pick up the production date..I had ti enter that manually.Can i set my car as the "default" or do i have to fill in the settings every time i open etk?.Sorry for the long post
    Gone but not forgotten
    *Bump* I'm going to learn along with you here OK?
    Tampa Bay, Florida, USA
    I have to enter my VIN every time. It's the best way to pull up the relevant data for your particular model.
    Ramon
    Default no comments???Ryan Bill R ??? nt
    bump
    Benneton (United Colors of)
    i don't think that you can set it to remember your car, because, after all, the ETK was not designed for personal use, and it would be of somewhat limited utility to a shop to keep a particular vin in memory for longer than it takes to find a part. i don't think that it automatically displays production date either. to find the vin produced one, you have to go to engine--vin specific i think. i think that the software automatically excludes parts that wouldn't fit based on prod date, or tells you specifically if there is a cutoff date.
    Apr 2004
    Wellington, NZ
    I have to put the VIN in each time, brings up all the correct info just no build date.
    Where abouts in NZ are you?
    Default i am in wellington too and just to make it more scary
    also have an 1989 535is
  1. E32 750iL questions to electronic gurus (long)
    Last Post: 07-16-2018, 05:04 PM
  2. Inspection Questions from a 1st time DIY'er - long
    By granit_silber in forum 5 Series BMW
    Last Post: 05-13-2005, 09:51 AM
  3. So Long
    By 1992 BMW 535i in forum 5 Series BMW
    Last Post: 09-02-2004, 08:25 AM
  4. MAF FAQ (long)
    Last Post: 07-15-2004, 07:37 PM
