Hey i've got a 89 520i and have got water issues as a result of the drain hoses in the sunroof lol, How do i get access to the drain hoses in the sunroof ?
guys
The drain holes are located at the four corners of the sunroof opening. I use vinyl coated wire and run the wire down through the drains to clean them out.Originally Posted by Fraz06
IIRC the front two tubes are metal while the rear two are rubber/plastic hoses. To gain access to the rear two you have to detach the headliner from the rear portion of the ceiling for one end; while the other end feeds into the rocker panels via the c-pillar.
-ashley
Paper Gaskets Suck!
