i would do the engine and trans mounts, new serpentine belt, and when thats off check the other items connected for play/siezing.
air intake temp sensor/gasket.
if you havent already, and you wanna get it over with, replace the power steering hoses. when they go its hell on earth to get em out and new ones on it.
thermostat, water pump, hoses, coolant bleed. only if needed.
steering box adjustment.
most of the other stuff i would say is either easy to do yourself, or hellish expensive.
