they are not a direct swap electronically, not sure if you can just swap the brain it may need the harness too which is fairly buried in the car, id find a 91-92 325/525 tranny and not need to screw with it, to use the 325 tranny just swap in your output flange, you don't usually even need to change the seal, otherwise it's a direct plug and play
