Results 1 to 10 of 13
Thread: 1990 535 Engine layout / photo?
    Apr 2004
    sunny SoCal, baby!
    Default 1990 535 Engine layout / photo?
    How the hell do I get to the goddamned spark plugs? (still waiting for my service manual to show up and I've never done this before) Do I have to remove what I think is the air filter?
    Is there a picture somewhere on the web of the 1990 535 engine that identifies the components? I'm trying to find one with no luck...
    for the love of god...
    *LOL* Bump
    Apr 2004
    sunny SoCal, baby!
    After you've wiped up the coffee that spurted from your nostrils on reading my previous pathetic post - should I hit the sauce 'til Monday or can I get at this plug business now?
    Go Leafs!
    Benneton (United Colors of)
    lemme see if i can find an m30 pic.
    Quote Originally Posted by cappy
    Go Leafs!
    ok, first of all, the manual doesn't have any pictures of m30 engines at the spark plug boots, so if you aren't familiar with what a spark plug wire looks like, i'd hold off and ask some more questions. your spark plugs are located on the passenger side of the car, probably below some plastic, but below the oil cap. i'd see if i can stick my hand down there and feel out 6 plug wires/boots. the wires travel through some type of plastic channel, so they aren't readily visible until they arrive at the plugs. you may or may not have to remove plastic and/or the air cleaner to get at it easily, (I own a m50 DOHC so they are on top of things), but they should be above the exhaust manifold and below the plastic air cleaner thingy. questions? maybe someone that owns a 35 will be able to answer you better.
    here we are then
    see the thing that says HT cable tray stud? i guess if there is a piece of plastic there, you'd remove it so that you can see the plug wires and plugs located beneath it, or if you can reach under it, i'm sure the latter would be preferrable.
    Apr 2004
    Cappy,
    Following this 'advice' depends on how far you made it into the sauce this weekend.
    Plug change out is a snap, but you do need a good plug socket that will hold the plug tight (little rubber bushing that grips the upper tip of plug), and a variety of 3/8" drive gear.
    Yes, remove the air cleaner: loosen the 4" dia. hose clamp going into the AFM (air meter), remove the top of the box + filter. Two more 10mm bolts and the base of the AC is out of the way.
    If you slightly warm the eng first, the plug wires will pull off more easily: Pull on the boot only. You can loosen the spark plug wire harness manifold (2 or 3 10mm acorn nuts on the valve cover) to again, make life easier.
    Once the wires are out of the way, the plugs are waaaay down in their wells - that's why the gripping socket. A little effort, and all 6 will be out.
    To reinstall - set gap of single electrode plugs @ 0.9mm
    - small dab of anti-seize on the threads (on nothing else!) - some will advise against anti-seize.
    - carefully lower the plugs into the well, and thread IN BY HAND. It is all too easy to cross thread in an aluminum head when you can't see the engagement. Snug to ~14 ft/lbs after correct threading is assured.
    Like I said, a piece of cake: So, what kind of sauce are we having?
    Tampa Bay, Florida, USA
    Additional Caveat to GS535's Post
    Make sure engine is COLD when you install plugs or else you'll end up messing up the threads.
    Default right, hot engine + R & R plugs = Stripped Threads,more...
    heres what I got out of the hammering I got when I recomended antisieze...
    Dontuse it, the new plugs (circa 1985+) have a zink coating in such no antisieze is needed. If however you do use it the torque setting to tighten the plugs will pull the threads right out of the heads.
    I do know for sure that you will mess up the threads if the engine is hot, learned that on crotch rockets a while back.
    Apr 2004
    sunny SoCal, baby!
    Thanks fellas - I'm going in and we'll see what happens. If I don't post back by Friday, I'm in rehab.
  1. 1990 525I engine size.
    By vping in forum 5 Series BMW
    Last Post: 03-29-2008, 11:10 AM
  2. Pin Layout for the ABS ECU- Anyone?
    By stilljester in forum 5 Series BMW
    Last Post: 12-05-2006, 09:52 PM
  3. Relay/fuse layout under rear seat 535is?
    By John 535is (Sydney) in forum 5 Series BMW
    Last Post: 09-09-2006, 03:24 AM
  4. Engine options for e34 520 1990
    By LordAlfa in forum 5 Series BMW
    Last Post: 08-16-2004, 08:37 AM
