Results 1 to 5 of 5
Thread: Coolant leak HELP ME PLEASE
    Cairo, Egypt
    Default Coolant leak HELP ME PLEASE
    I suspect my block is leaking coolant. What do you think if I take out the thermostat (mechanical one leading to the engine block) and do the pressure test to find out if my block has leaks. Does this make any sense. The pressure test does not lead to anything now with the thermo in and I loose around a cup a day and see no leaks and nor pressure drop on the test. I also blocked the heating matrix out of the circuit to rule this option out. I am going to fry the engine if I keep on loosing coolant. I will forget some day to top it off.
    1990 520i M20 Manual, 16" wheels 225/50 Conti's Bi-Xenon. Crystal tail lights. Sachs lowering kit. MOMO steering wheel and shift knob. Pioneer sound system all around.
    baton rouge, loserana
    the thermostat has no bearing on a pressure test at all, matter of fact it may leak without it as the o-ring is not really big enough to seal without the t-stat taking up space, if you are leaking externally it will leave traces you just gotta find them
    USA
    how does your oil look?
    Sep 2006
    Leuchars,Scotland
    check ur oil,and check ur exhaust smoke for steam (excessive whiteness) compression test the engine to make sure u havent got a chamber-water channel leak and if i were u i wouldnt drive it much til it doesnt lose water. it may be taking air into the system at the point its leaking which if left unbled will cause overheating
    Sig car has gone, but buying an E34 on my return to Britain in 3 months
    Windy City
    I had a similar coolant problem recently. I would loose about a cup a day but couldn’t find any leaks on the ground. It turned out to be a small crack on the coolant expansion tank. The crack was so small that it will only leak very small amount as the engine is hot and that small amount evaporate from heat. A friend had a similar problem with his Mercedes with same expansion tank leak. I took the tank out and took a very close look at it and found the crack. Now after the replacement tank, no more coolant lose…
    Quote Originally Posted by aabdelhamid
    RICK
    BMW 1995 525i (Alpine White)
  1. Follow-up on my M50 oil leak & coolant leak
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 03-06-2008, 10:51 AM
  2. Coolant leak
    By 52vincent in forum 5 Series BMW
    Last Post: 02-05-2008, 09:51 AM
  3. Coolant leak
    By peterllo in forum 5 Series BMW
    Last Post: 01-25-2005, 04:02 PM
  4. Most likely coolant leak in V8?
    By ra_pro in forum 5 Series BMW
    Last Post: 01-11-2005, 04:31 PM
  5. Coolant leak (yay!)
    By Craig in forum 5 Series BMW
    Last Post: 06-23-2004, 10:58 AM
