Results 1 to 10 of 11
Thread: Hissing Sound From Back of M60
    ~30 Miles North of Chicago, Illinois
    Default Hissing Sound From Back of M60
    Noticed this today,
    With the hood open & engine running after returning from a ride I heard a hissing noise coming from the back of the engine. Also seemed to be more on the passenger side.
    I could change the hissing (lessen?) by opening the throttle a little bit, and if I flicked the throttle, the area the hissing was coming from would make a hic-up type sound.
    I searched & didn't really find anything that matched.
    Car has been running just same as always (knock on plastic wood)
    Is this the infamous M60 intake gaskets leaking/sucking air in?
    [1994 530i/5-Speed]
    did you get any CEL codes yet?
    Quote Originally Posted by Fetch
    Nope nothin' yet,
    maybe as it gets colder out I'll be so lucky
    [1994 530i/5-Speed]
    Ga
    Ive noticed this sound many times on this engine. I would call it normal, if there were a massive vacuum leak like that, your car would be running like crap. Alot of times in the CC vent valve has blown out (the one at the back on the intake) it will make a honking type noise and youll be sucking oil into the intake causing white smoke at start-up.
    -Ben
    baton rouge, loserana
    spray carb cleaner all around the intake and see if the idle changes while the engine is cold and again when its hot if you get nothing cold, the honking sound is not a dead giveaway, out of probably a dozen blown plates i've only seen one honk
    Elm Grove Farm, NC
    Sounds like it could be the infamous throttle plate diaphragm leaking (#3 in this diagram):
    http://realoem.com/bmw/showparts.do?...98&hg=11&fg=40
    It's evidently a fairly common failure. I've seen info online about it and how to fix it.
    Bret.
    USA
    BAV auto has a kit that contains the gasket and parts needed to replace the entire thing for something like $65
    Thanks everybody, going to check it out further
    [1994 530i/5-Speed]
    OK, I checked it out, I've got to leave soon, so I will post pictures later today, but:
    I took the plastic beauty cover off the engine and even before starting the engine was able to guess where the hissing sound was coming from just by looking!!!
    The vacuum hose connected to the part 'inbetween' parts #12 and #2 was cracked at the end, sure enough this was causing the noise. I clipped off the bad part of the hose & reconnected it (hose should be replaced if I do any work with the intake (gaskets) though).
    http://www.realoem.com/bmw/showparts...85&hg=13&fg=15
    Is this 'unnamed' part, part of the pressure regulator (#4)?
    Also, there was a two pronged wiring harness (not plugged in) tucked away under the fuel rail I hadn't noticed before....I'll post pics, but I couldn't find anywhere this thing is supposed to be connected...donno what it's for.
    [1994 530i/5-Speed]
    yea thats the regulator, don't worry about the extra plug it's for something you don't have
  1. Hissing sound & petrol fume smell
    By ktteoh in forum 5 Series BMW
    Last Post: 08-12-2006, 11:22 AM
  2. Should she be hissing at me??
    By Rob in forum 5 Series BMW
    Last Post: 04-04-2006, 12:00 AM
  3. Hissing sound and exhaust smell under the engine?
    By Interceptor in forum 5 Series BMW
    Last Post: 10-15-2005, 11:04 PM
  4. Hissing sound from fuel pump...
    By Rick L in forum 5 Series BMW
    Last Post: 07-29-2004, 12:14 PM
  5. Fuel pump hissing sound?
    Last Post: 05-10-2004, 09:53 PM
