Results 1 to 5 of 5
Thread: Where is the check valve in the brake booster?
    Norcross, GA
    Default Where is the check valve in the brake booster?
    I dont see the check valve in the brake booster vaccum tube. Is it built inside our brake boosters?
    How difficult it is to change the vaccum tube in the brake booster?
    Arun
    530i / Nikasil M60 3 Ltr Motor / ZF5HP18 (A5S 310Z) Tranny / Prod: March 95 / Fully stock / 95K miles
    Cincinnati, Ohio
    ~30 Miles North of Chicago, Illinois
    I'm 99% sure I don't have a check valve as pictured on my brake booster vacuum line....
    Is this why after my engine is shut off I loose power brakes after barely 1-2 pumps of the pedal?
    [1994 530i/5-Speed]
    Aug 2006
    Boulder, CO, USA
    No that is normal, brakes require quite a bit of vacuum to get the assistance they provide. The check valve is a one way valve so that vacuum stays in the booster when the engine isn't making much vacuum (i.e full throttle). If it weren't there, the brakes would get rock hard after you were on the gas.
    Norcross, GA
    Quote Originally Posted by neil_004
    Thanks Neil.
    Any one knows the procedure to change part 6?
    Arun
  1. squeaky noise at brake pedal- lubriacte the brake booster?
    By werminghausen in forum 5 Series BMW
    Last Post: 06-12-2008, 01:22 PM
  2. brake booster vacume valve
    By bones in forum 5 Series BMW
    Last Post: 08-28-2007, 08:18 AM
  3. e34 520i 1988 brake servo/check valve...
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 06-25-2006, 07:27 PM
  4. Replies: 7
    Last Post: 09-12-2004, 04:37 PM
