Results 1 to 7 of 7
Thread: Drivers side window out of sync?
    Default Drivers side window out of sync?
    The tinter dude ran the batteries completely dead, now the drivers window wont drop the 1/4 inch it's supposed to when opening the door, it also will run all the way up its travel and then reverse all the way down with no stop at the top...
    any clues?
    On the good side, there are no longer any codes or warnings now except the SRS light...
    Jun 2005
    Cheshire, UK
    any clues?
    Plenty. You want some answers?.......
    1997 e39 523SEi touring.
    answer me biatch! lol, Stu you rule.
    Quote Originally Posted by Omega
    baton rouge, loserana
    i've not done this to a e31 but it works on e36s, run the window all the way up and down a couple times with the door closed and it learns it's place, if the window stops hit the switch again till it gets to the end of it's travel
    Jun 2005
    Cheshire, UK
    Winfred beat me to it!!!!
    I have also read that you run the window closed (pressing on the button, not using the one-shot lift) and keep holding the button down for 3 seconds once the window reaches the top. The window should then drop a bit and then goto the closed position.
    It is now sequenced, and knows it's arse from it's elbow once again.
    will try tonight!
    you guys rock! window works as good as new!
  1. Stuck drivers side window
    By SKB in forum 5 Series BMW
    Last Post: 10-04-2006, 10:14 AM
  2. drivers side window clunking
    By dan0235 in forum 5 Series BMW
    Last Post: 06-24-2006, 01:51 PM
  3. Drivers side Window problem again
    By Al Gray in forum 5 Series BMW
    Last Post: 04-17-2006, 04:23 PM
  4. Drivers Side Window Issue, Again!
    By wishihad50k in forum 5 Series BMW
    Last Post: 05-10-2005, 04:19 PM
  5. Drivers Side Window Fell Out...
    Last Post: 04-19-2005, 03:28 PM
