Thread: Replacing door seal gaskets
    Default Replacing door seal gaskets
    I received 4 in the mail from malaysia and I don't know how to stick the screwdriver in to take the handles off. I've seen links that Shogun has posted to Japanese sites to remove it that looks easy. But I don't want to hit the panel work inside or much up the lock mechanism. I'm trying pretty hard with a screwdriver pushing against it to remove it but it won't budge.
    Hockinson, Washington
    there is a little lever, you can see it with a flashlight. Hold the handle so it doesnt drop to the ground.
    cool. I didn't use a flash light actually, I was going in blind. Thanks for the quick reply Alex.
    what's the problem?
    You are talking about japanese instructions which you do not like???
    I think you are still having in your brain the japanese girl, for which I have to translate your lover letters
    How about this in English
    http://www.bmw4life.com/doorHandle.htm
    Instead of a screwdriver use a normal wrench, much easier and less damage.
    Wellington,New Zealand
    its the other way thats a bit harder.I made a little wire hook to pull them back,but i need to reposition the handle slightly as the handle hits the surround and sticks up sometimes
    Gone but not forgotten
    Yeah thanks for the bmw4life link - I didn't unhook the metal bit with a screwdriver.
    I've only tried the left hand side (passenger side) so far.
    what's the problem?
  1. Replacing front crank seal - what else?
    By J.DeFeo in forum 5 Series BMW
    Last Post: 06-22-2008, 02:55 PM
  2. replacing valve cover gaskets
    Last Post: 02-04-2007, 12:42 PM
  3. Some notes on replacing the sunroof seal
    Last Post: 12-02-2006, 01:41 AM
  4. Replacing timing chain and gaskets on M42
    By intelitre in forum 3 Series BMW
    Last Post: 06-12-2004, 08:57 PM
  5. Replacing windscreen seal - need part number?
    By John 535is (Sydney) in forum 5 Series BMW
    Last Post: 05-16-2004, 10:07 PM
