Bizarre.
But you have my favorite wheels!
OK, i was lucky enough to join Scott, JR, Kris, Brandon J at Dave Rs house last weekend in Chicago for the subframe bushing rally and while it was on the rack we all noticed my tank has imploded! Now I ran it dry (gasp) late this summer less than one block from the gas station-- are there any other possibilites for this? Any remedies or am I stuck with a smaller tank now or need to r/r?
Now I know why it only takes 15 gals to fill it up!
Bizarre.
usually a mud dauber nest in the tank vent or something like that, been a while and i can't remember where it's located on that car, usually up in the right rear wheel well
First my exploding fuel pump, now a imploding tank!
I have never seen anything like that myself, is there like a dent in the tank or something? I would love to see a picture of that!
So there is a tank vent someplace other than in the gas cap? Most vehicles have pressure and vacuum relief valves in the cap. Are the valves in the top of the tank (fuel pump access hatch?).Originally Posted by winfred
I have seen a Citroen diesel with a collapsed tank. There was no pushing the 'dent' out of it manually. It collapsed in a way that stopped the gauge float at 1/2 tank. Not good!
Brian
they can suck the tank totally flat, looks like a raisin
Originally Posted by Milkboot
my old cam used to cause a whoosh sound from vacuum when I took it off, new cap=no vacuum
Ill try and get one if I can get in on a lift again. Its pretty impressive/scary/. Ill replace the cap as a starter though. Who knows...
Here was my old tank that the genius's at the tire balancing place put in mine. You can see it was imploded and the support bars didn't even reach the tank. (They didn't have an IQ over 7)
Who's the babe?( that better be a girl....)
1995 540i Manual build 1/95
