I very much doubt it.
Dude, only way to find out if said item is working is to buy one, Get diappointed, de-install the **** and send it back and waste the bastards' time...Originally Posted by grave77
I would not go anywhere near that contraption. It seems no different than the usual powerchip (aka stick a resistor in your MAF harness) power recipe. Modifying the oxygen sensor signal (if it even does that) will most likely affect the emissions of the vehicle and may trigger your check engine light if the new "modified" signal doesn't please the ECU. Sounds like another snake oil power booster. Just my $.02
Its the old "$0.02" Resistor (literally) in series with the sensor trick - it (temporarily) fools the ECU into over fuelling ... essentially can only ever "work" if your sensor(s) are crap now and hence you have lost that performance in the first place - even then it may not work - much better to fix the sensor problem permanently.
'90 535iSE Auto (AE+EAT) 123k miles
'86 F288 69k miles
'06('89)- PGE 2.0DOHC Turbo
'03 A160LE 19k miles
1914 Stellite E2A (no odometer!)
(+ others I daren't mention here)
www.pyghtle.com
so they are simply fooling ppl ... as they said This Is not a Resistor ... the only problem is that WHY NO ONE GIVE THE PROPER FEEDBACK IN EBAY !!
mattering what year you have and dmi unit, these will help:
http://www.turnermotorsport.com/html...1&subcat_id=74
It's bound to work
See Euro Quality!
www.universal5.com
Orange Tool Forum
San Diego, CA
1994 e34 530i Eibachs/KYB
0 miles on new windshield
Have you got an 850? !! I think someone else is sharing my misery :P ... Tuner ppl are expensive, also I don't know how accurate the info they have written, I wanted to contact mark D, what's your ideas? congratualtions dude on ur E31 ... welcom to the club
