Results 1 to 10 of 12
Thread: How to Raise the idle on 540i
    Default How to Raise the idle on 540i
    Does anyone know how to do this? My idle is 450-500 most of the time in drive and tends to run a little rough. If I give it a little gas and bring it up to 600-700, it smooths out nicely. Any suggestions?
    Brian
    Tampa Bay, Florida, USA
    EAT Chip smoothed out my idle.
    Ramon
    same question here, 530
    SCHUYLKILL COUNTY, PA.
    Default try cleaning out the icv. my 540i/a idles @ 500-600
    tim s.
    new540iowner Guest
    Default Can you elaborate on the EAT chip improvement to idle?
    I'm considering the chip and my idle is the principal reason I would buy it. My 94 540 also idles in the 500-600 range and would like it to idle, forgive for saying this, more like a Toyota. Car runs great, as one forum member said, above 700 RPMs but the idle is making me consider another car.
    What's the ICV?
    Default idle control valve...........
    round shiny cylinder on top of the throttle body. first remove fancy bmw engine cover. there is a small tube that comes from the top of the intake boot then connects to the icv. remove the idle control valve from the throttle body, remove small tube, & disconnect wire connection. clean thoroughly w/intake cleaner. a small moving part inside should move freely. they tend to get dirty & not move properly.
    enjoy
    tim s.
    I'll try it. Thanks Tim!
    Default EAT Chip Test
    I posted my EAT Chip test results a week ago. Do a search on EAT or my ID.
    Ramon
    MBXB
    Quote Originally Posted by new540iowner
    Default ICV Cleaning
    Tim,
    Is this something easy to do when I'm changing plugs, since I'll have the cover off anyway?
    Ramon
    Quote Originally Posted by tim s
    enjoy
    tim s.
  1. raise the idle on m30
    By bmw210 in forum 5 Series BMW
    Last Post: 05-30-2006, 09:41 AM
  2. 94 540i rough idle
    By ammo00 in forum 5 Series BMW
    Last Post: 01-16-2006, 03:18 PM
  3. 95 540i shaking at idle
    By ra_pro in forum 5 Series BMW
    Last Post: 11-02-2005, 02:35 PM
  4. Replies: 9
    Last Post: 10-11-2005, 04:41 PM
  5. what should my 540i/a idle at?
    Last Post: 10-02-2005, 05:13 PM
