Results 1 to 4 of 4
Thread: Whats in a "engine block gasket kit"?
    PA
    Default Whats in a "engine block gasket kit"?
    I ordered a bunch of **** for my other motor build and in specific, I got the "lower enging block gasket kit" I could see it had the oil pan gasket and some other crap, but I couldn't tell specifically whats in it. I also ordered timing cover gaskets (hopefully they're not in the kit), and gaskets up top (valve cover, spark plug gasket, grommets, etc).
    Any ideas?
    Hmmm,
    My guess is, other than the oil pan gasket,
    Rear main seal
    Rear main cover gasket (paper)
    Front crankshaft seal
    Lower tiiming case gasket (not sure about the upper metal guy)
    Hows the supersized M50 rebuild going?
    PA
    Thanks dave - just kind of starting out
    costs a bunch
    baton rouge, loserana
    a "conversion set" has pretty much everything that doesn't come in a head set, everything below the head gasket
  1. M50 "blind plug" on front of block
    Last Post: 09-08-2007, 10:02 AM
  2. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  3. "Chattering" sounds from tranny, whats causing it???
    By GoldenOne in forum 5 Series BMW
    Last Post: 03-21-2006, 07:17 AM
  4. Whats the definition or "rough idle" 540i\6sp
    By wmann in forum 5 Series BMW
    Last Post: 05-09-2005, 08:38 AM
  5. Whats the "Big Time Poster" criteria?
    By DaCan23 in forum 5 Series BMW
    Last Post: 06-14-2004, 07:15 PM
